Upgrade Your Rear Brakes With CPP’s 12″ Big Brake Kit (1012RWBK-12)
If you’re running a ’62–’67 Chevy II/Nova or a ’67 Camaro and want to seriously improve your rear stopping power, check out CPP’s 12″ Rear Big Brake Kit (Part #1012RWBK-12).
🔧 What It Is:
This is CPP’s heavy-duty 12-inch rear disc brake conversion kit designed to bolt right on to GM 10-bolt or 12-bolt rear ends where applicable.
💪 Why It’s Awesome:
• Large 12″ drilled & slotted rotors give you extra braking surface for improved heat management and stopping power.
Powder-coated black calipers add both performance and style under your wheel.
• Comes with stainless steel brake hoses and parking brake functionality included — no guessing on parts you might still need.
Bolt-on fitment means a straightforward install on compatible rear axle flanges.
🛞 Fitment Notes:
You’ll need minimum 15″ wheels for proper clearance between the caliper and rotor.
🚗 Whether you’re restoring a classic or building a pro-touring ride, this kit gives your rear brakes a big performance bump without crazy fabrication.
