NEW PRODUCT: CPP Premium Nova Lower Ball Joint + FitRight™ Lock Nut
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
If your Chevy II or Nova steering feels loose, noisy, or just not as tight as it used to be… there’s a good chance your ball joints are worn out. CPP just released a Premium Nova Lower Ball Joint, and it’s paired with their NEW FitRight™ Flanged Lock Nut, designed to outperform factory components and bring your steering back to life.
Why This Matters​
Worn ball joints are one of the most common causes of:
  • Steering play
  • Clunking noises
  • Poor handling feel
  • Uneven tire wear
If you’ve ever felt your Nova “wander” down the road or heard noise from the front end… this could be your fix.
What Makes This CPP Ball Joint Different?​
This isn’t just a replacement—it’s an upgrade.
CPP designed this ball joint specifically for classic Novas, using modern materials and tighter tolerances to improve performance and durability.
🔹 Key Features:​
  • Advanced low-friction internal design for smoother steering
  • Hardened, precision-machined components for longer service life
  • Reduced play and noise for a tighter front end feel
  • Includes NEW FitRight™ flanged lock nut for secure retention
  • High-quality flanged mounting hardware included
  • Protective rubber boot keeps out dirt and moisture
Built for Real-World Driving​
One of the biggest killers of ball joints is contamination.
CPP addressed that with a durable rubber boot that seals out:
  • Road debris
  • Moisture
  • Dirt
That means longer life and more consistent performance—whether you’re cruising, daily driving, or pushing your Nova a little harder.
Let’s Talk About the FitRight™ Lock Nut​
This is a small detail that makes a big difference.
The FitRight™ flanged lock nut:
  • Provides better load distribution
  • Improves thread engagement
  • Helps ensure a secure, reliable install
It’s one of those upgrades you don’t think about—until you realize how important it is.
Who Is This For?​
This upgrade is perfect if you are:
  • Restoring a classic Nova
  • Rebuilding your front suspension
  • Upgrading for better drivability
  • Trying to eliminate steering play
💬 Let’s Hear From You​
  • Have you replaced your Nova ball joints recently?
  • What symptoms did you notice before swapping them out?
  • Anyone already running CPP suspension components?
Drop your experience below 👇
🔗 Learn More / Shop:​
👉 https://classicperform.com/shop/cpp407
🏁 Final Thoughts​
If you’re looking to tighten up your steering and improve overall driving feel, this is one of those upgrades that makes an immediate difference.
