Ditch Manual Steering on Your 60–62 C10 – Here’s the Upgrade You Need
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
If you’re still running manual steering on your 1960–62 Chevy C10… you already know—it’s not exactly fun in tight spots Parking lots, slow turns, and even cruising can feel like a workout. But the good news? There’s a clean, bolt-in solution that completely changes the driving experience.
CPP 6062PSK-S Power Steering Conversion Kit
This kit is designed specifically for 1960–1962 C10 trucks with small block engines, and it gives you modern steering feel without hacking up your truck.
What You Get
  • Power steering gearbox
  • Power steering pump
  • Pump bracket
  • Hoses and fittings
  • Pitman arm
  • Rag joint
  • Mounting hardware
👉 Only thing not included is the pump pulley
Why This Upgrade Is Worth It
Let’s be honest—manual steering has its place… but drivability isn’t one of them.
With this kit, you get:
✔ Much easier turning at low speeds
✔ Better control on the road
✔ Reduced driver fatigue
✔ A more modern, confident driving feel
This setup runs a 16:1 ratio with about 4 turns lock-to-lock, which makes a huge difference behind the wheel.
🛠️ Install Notes
This is a direct-fit kit, so everything is designed to work together.
A few quick tips:
  • Make sure your pulley setup is correct
  • Double-check hose routing and clearance
  • Verify steering column connection
  • Take your time aligning everything properly
Overall, it’s a very straightforward upgrade compared to piecing together a system.
Who’s Running Power Steering on Their Early C10?
Let’s hear it 👇
  • Are you still manual steering?
  • Already upgraded?
  • Planning a restomod build?
Drop your setup, pics, or questions below 👇
Always cool to see how everyone is building their trucks.
Check Out the Kit Here
https://classicperform.com/shop/6062psk-s
CPP – Built to Fit. Built to Perform. Built to Drive.
