If you’re driving a 1947–1953 Chevy truck, upgrading to a modern disc brake system is one of the smartest improvements you can make. The CPP Complete Disc Brake Kit with Firewall-Mounted Booster is designed to give your vintage truck the stopping power, control, and confidence needed for today’s roads.
The Problem with Original Drum Brakes
Vintage trucks were built for a different era—lighter traffic, slower speeds, and fewer demands on braking systems.But today?
Drum brakes can struggle to keep up.
Here’s what most drivers experience:
- Fading brakes during repeated stops
- Increased pedal pressure required
- Inconsistent braking performance
- Reduced confidence in emergency situations
A Complete Bolt-On Brake Solution
Instead of piecing together parts, CPP offers a complete, engineered system designed specifically for your truck.This kit is built to:
✔ Work with your factory spindles
✔ Deliver balanced braking performance
✔ Simplify installation
Everything is designed to function together—eliminating guesswork and compatibility issues.
Power Assist That Changes Everything
One of the biggest upgrades in this system is the firewall-mounted power brake booster.Unlike older setups, this configuration provides:
- Stronger, more consistent brake assist
- Reduced pedal effort
- Improved driver control
Clean Installation with a Modern Feel
This kit doesn’t just improve performance—it improves the overall driving experience.What makes it stand out:
- Firewall-mounted design for better ergonomics
- Clean, organized engine bay layout
- Straightforward installation process
Built for Today’s Wheels and Builds
Another major advantage?That opens the door to:
- A wider selection of wheels
- Pro-touring and restomod styling
- Improved overall vehicle stance
Perfect for Drivers, Not Just Show Trucks
This upgrade isn’t just for looks—it’s for trucks that get driven.Whether you're:
- Cruising on weekends
- Driving to shows
- Building a reliable restomod
Feel the Difference Every Time You Drive
The first time you apply the brakes after upgrading, you’ll immediately notice:- Smoother, more controlled stops
- Faster response from the pedal
- Increased confidence in traffic
Why Builders Choose CPP
CPP is known for delivering high-quality components designed specifically for classic vehicles.Instead of adapting generic parts, CPP focuses on:
- Proper fitment
- Matched system performance
- Real-world drivability
