Key Details & Features
Engineered specifically for 1955–57 full-size Chevy models, this 1¼″ hollow sway bar delivers maximum rigidity with reduced weight. Its high-clearance design provides improved fitment under the chassis and offers better room for wider front tires—solving the clearance issues common with standard sway bars.Instead of traditional fixed bushings, the kit uses rod-end style end links, allowing smoother articulation and sharper handling response.
Included in the Kit
- 1¼″ hollow front sway bar
- Polyurethane bushings
- Rod-end style end-link hardware
- Black billet sway-bar clamp
- Mount spacers and hardware
- Greaseable mounting bracket with a built-in Zerk fitting for easy maintenance
Read the full article here
