Upgrade Your ‘64 Chevelle with Premium Billet Hood Hinges
Introducing the EMS149-56MB Kit
If you’re restoring or customizing a 1964 Chevelle and want that perfect mix of form and function under the hood, the EMS149-56MB billet hood hinge kit deserves a look. Offered by Classic Performance Products (CPP), this kit brings together high-end materials, precision design, and finishing touches that elevate both performance and aesthetics.
What Exactly Is EMS149-56MB?
Let’s break down the key specs and features:
| Feature | Detail |
| Product Name / SKU | Eddie Motorsport Hood Hinges Pair, 64 Chevelle, Matte Black — EMS149-56MB |
| Finish | Matte black Fusioncoat |
| Material | Aluminum construction |
| Includes | Stainless steel gas struts (i.e. hood lifting supports) |
| Fitment / Application | For 1964 Chevelle with steel hood |
These aren’t your garden-variety hinges. They’re billet components, machined from aluminum, with a durable matte black finish that resists corrosion and offers a modern look under the hood.
Why Choose Billet Hinges Over Stock?
If you’re on the fence about upgrading hood hinges, here are some compelling reasons to go billet:
- Strength & Precision
Billet aluminum, especially when CNC-machined, offers better consistency, tighter tolerances, and improved structural integrity compared to stamped steel hinges. That helps reduce unwanted flex, sag, or misalignment over time. - Aesthetics That Show
Under-the-hood presentation matters — whether for car shows or just pride of ownership. The matte black finish gives a clean, aggressive look that pairs nicely with engine bay upgrades. - Integrated Gas Struts
Rather than relying on prop rods, the included stainless gas struts make opening and holding up the hood effortless and clean-looking. - Long-Term Durability
Good aluminum hinges with quality finishing are less prone to rust/decay over time compared to original steel hinges — especially in climates with moisture or salt exposure.
Installation & Fitment Tips
Here are a few pointers to make sure your install is smooth:
- Check hood alignment carefully — aftermarket hinges may require shimming or minor adjustment to align with existing hood latch points.
- Use thread locker on bolts — to prevent loosening under vibration.
- Lubricate pivot points after installation to ensure smooth operation.
- Test strut strength — make sure they hold the hood reliably without overexertion (or underperformance).
- Mock-up before final tightening — open/close several times to confirm clearance, binding, or interference before torqueing down every fastener.
Who This Is For
The EMS149-56MB is ideal for:
- Restorers who want better-than-stock performance under the hood
- Show car builders who care about presentation
- Hot-rodders upgrading their engine bay and supporting components
- Owners of 1964 Chevelles who want modern convenience (gas struts, smooth operation) without compromising style
If you’re doing a full engine bay overhaul — adding custom wiring, cold-air intakes, or visual detailing — these hinges help carry the look through to the hood area.
Potential Considerations / Caveats
- The quoted lead time (25 days) is relatively long; plan accordingly if you have a build timeline.
- Price is premium — it’s not the cheapest hinge upgrade, but you’re paying for quality, fitment, and finishing.
- Because these are for steel hoods, compatibility with aftermarket fiberglass or composite hoods should be double-checked.
Final Thoughts
The EMS149-56MB billet hood hinge kit from CPP / Eddie Motorsports is a smart upgrade for anyone working on a `64 Chevelle and aiming for a blend of performance, durability, and show-ready style. It’s built tough, finished clean, and gives you that smooth, modern hood operation you expect on a high-end build.
