Upgrading a vintage muscle car or pickup to electronic fuel injection (EFI) is one of the single most transformative performance enhancements you can make. Gone are the days of finicky carburetors and constant tuning—EFI delivers precise fuel metering for smoother throttle response, better cold starts, and improved fuel economy. CPP EFI systems streamline this transition with purpose-built, drop-in fuel tanks that are engineered from the ground up for EFI readiness.
What Makes CPP EFI Different?
CPP’s EFI-Ready Tanks are more than just a fuel reservoir—they’re comprehensive, vehicle-specific solutions designed to save you time and worry:
- Original-Fit Tank with Built-In Fuel Tray
Every tank is perfectly shaped to your application, so there’s no cutting or hammering required. - Complete Hardware Kit
Includes all mounting brackets and straps, a calibrated sending unit, fuel filter/regulator, and a high-flow in-tank pump capable of supporting up to 600 hp (with optional higher-volume upgrades). - All-Inclusive EFI Fuel Line Kit
Push-lock hoses and anodized fittings run from the pump outlet to the front of the vehicle—no special tools, no aftermarket adapters.
Installation Made Simple
Whether you’re tackling your build in a home garage or workshop, CPP EFI tanks eliminate many of the headaches that come with retrofitting EFI:- Bolt-In Fitment
The tank drops into the factory location using the supplied hardware—no frame modifications needed. - Plug-and-Play Plumbing
Push-lock hoses snap onto the included fittings for leak-free connections without crimpers or swagers. - Pre-Set Pump & Regulator
With the in-tank pump and regulator pre-tuned for EFI flow rates, all that’s left is plumbing and wiring.
Built to Last
Corrosion is the enemy of any fuel system. CPP EFI tanks are fabricated from durable, corrosion-resistant materials and finished with a protective coating, ensuring long-term service life—even when exposed to ethanol blends. Plus, the 255 lph pump is rated for continuous duty up to 600 hp, with higher-capacity options available for serious power goals.
Applications & Availability
From 1950s full-size Chevys and first-generation Mustangs to late-’70s Camaros, El Caminos, and more, CPP offers EFI-Ready Tanks for a wide range of popular classics. Each application kit is in stock and ships in about 10 days, making CPP EFI one of the fastest ways to get your classic car or truck running like a modern machine.
Ready to modernize your fuel system?
Explore the full line of CPP EFI kits at ClassicPerform.com and give your vintage ride the reliability and performance it deserves!
