If you’re restoring, customizing, or just want your ride to look as killer under the hood as it does cruising down the street, the CPP MidNite Series is made for you. Classic Performance Products (CPP) has designed this line to deliver top-tier performance and sleek aesthetics, because why sacrifice look for function?
⚫ What Is the MidNite Series?
The MidNite Series from CPP is all about combining black-finished brake booster and master cylinder kits with serious versatility. These kits offer modern styling for your engine bay with the hard-working capacity you expect from high-quality braking components. Whether your project is a classic truck, a ’60s muscle car, or a custom build, the MidNite Series has something that’ll fit your rig and your style.
⭐ Key Features & Benefits
  • 🎨 Black Finish Aesthetic: Deep black components give the engine bay a clean, modern, aggressive look, making other parts (like chrome or polished pieces) pop.
  • 📏 Wide Size & Application Range: Boosters from 7″ up to 11″ diameter, with single or dual diaphragm options. Universal kits are available, plus vehicle-specific kits making installation simpler and cleaner.
  • ⚙️ Master Cylinder Choices: Lightweight cast aluminum master cylinder with GM-style proportioning valve, or custom master with flat top lid and adjustable valve — both offered with 1” or 1-1/8” bore sizes for tailored pedal feel.
  • 🛑 Performance and Safety: Engineered to work with both 2-wheel and 4-wheel disc systems. Better brake response, reliable stopping power, and improved control under load.
🚗 Applications
If you’re doing one of these builds, the MidNite Series might be exactly what you need:
  • 🐎 Restored classic Mustangs, Camaros, Chevys, F-Bodies, A-Bodies with upgraded braking safety.
  • 🔥 Hot rods and custom builds where styling and performance both matter.
  • 🛻 Trucks from the ’50s-’70s being updated with modern brake systems.
  • 🧰 Builders needing universal or vehicle-specific kits with booster/diaphragm/bore options.
⚠️ Things to Consider
  • 📐 Fitment / Size Constraints: Check firewall clearance and pedal location.
  • ⚖️ Brake Proportioning: Match master cylinder bore & valve to your setup for balanced braking.
  • 🧴 Finish Care: Black finishes look great but need sealants and proper cleaning to prevent wear.
🏆 Why CPP MidNite Stands Out
CPP has decades of experience in the performance/restoration world. The MidNite Series blends proven engineering with show-car style, giving builders the confidence of performance parts with the aesthetics to stand out at any cruise-in or car show.
