Transforming a 1967–72 C10 with a CPP Pro Touring Coilover Conversion
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
Jason Scudelleri of HB Hot Rod recently gave us a front-row seat to an epic suspension upgrade on a classic Chevrolet C10 frame. In a short, action-packed Instagram video, Jason walks us through unpacking, prepping, and installing the CPP Pro Touring Kit’s coilover conversion components. The result? A dramatic improvement in stance, handling, and overall street cred. Here’s a deeper dive into what went down behind the camera.
1. Unboxing the Hardware 📦
Behind Jason lies a mountain of precision-engineered parts: coilover assemblies, upper and lower control arms, steering linkage, pitman and idler arms, and a high-clearance sway bar. Each component is proudly made in California and powder-coated for durability and style. This kit is designed to bolt directly onto a restored C10 frame—no guesswork required.
2. Prepping the Powder-Coated Frame 🛠️
Before any suspension bits can go on, the frame itself needs to be stripped. Jason shows us where to drill out rivets and remove factory hardware, clearing the way for fresh, modern components. Having the frame powder-coated and painted ahead of time not only ensures corrosion resistance but also gives the truck a rock-solid foundation for its new underpinnings.
3. Installing the CPP Pro Touring Coilover Kit ⚙️
With the frame prepped, Jason tackles the heart of the upgrade:
  • Upper & Lower Control Arms: CNC-machined for precise geometry, these arms position the coilovers perfectly.
  • Coilover Shocks: Adjustable spring preload and ride height let you dial in handling and stance.
  • Steering Linkage: Includes new pitman arm, idler arm, and tie-rod ends for crisp steering response.
  • High-Clearance Sway Bar: Provides additional roll stiffness without binding during suspension travel.
Jason highlights how everything bolts up using factory mounting points—no extra brackets or custom fab work needed.
4. First Impressions: Day vs. Night of Difference 🌅🌃
“Man, what a difference,” Jason exclaims once the front end is buttoned up. The C10 instantly gains a more aggressive stance, improved cornering capabilities, and a smoother ride. While the video only covers the front suspension, you can already see how transformative this conversion is. Jason closes by teasing Phase 2: tackling the rear suspension next.
5. Why Choose the CPP Pro Touring Kit? ✅
  • Precision Engineering: All parts are designed and built in-house at CPP’s California facility.
  • Bolt-On Installation: No custom fabrication means faster installs and fewer headaches.
  • Adjustability: Coilovers let you fine-tune ride height and spring rate to your driving style.
  • Complete Solution: From control arms to sway bar, everything you need is in one box.
Conclusion & Next Steps
If you’re building a classic C10 and want modern handling with a pro-touring vibe, the CPP Pro Touring Coilover Conversion Kit is tough to beat. Stay tuned for Jason’s follow-up video on the rear suspension install, and be sure to check out HB Hot Rod for more in-depth shop builds and real-world driving impressions.
