The Right Fit for Every Build
Tired of wrestling with fitment headaches during your LS engine swap? CPP FitRite puts the precision and adjustability you need right at your fingertips. Engineered for seamless bolt-in installation, FitRite mounts and plates offer up to 3½" of clearance adjustment, no cutting, no guesswork. Made of rugged steel with vibration-dampening Poly or Rubber pads, they ensure a durable, smooth, and reliable fit.
Ideal for classic muscle cars and trucks, from Camaro to C10, CPP FitRite transforms your build with flexibility, strength, and a clean installation, letting you focus on the drive, not the drive to the parts store.
Key Features Highlight:
  • Adjustable Fit: For perfect engine placement
  • Polyurethane or Rubber Options: Choose the pad material that suits your ride, great for shock absorption and performance
  • Bolt-On Ease: Designed to fit with OEM holes, no welding or custom mock-ups needed
  • Heavy-Duty Build: Made of high-strength steel, built to take it
Upgrade your LS swap with CPP FitRite today. Click the link to gear up for your next build, and make every bolt count.
