Streamline Your LS/LT Swap: The Ultimate Guide to CPP Harnesses & Accessories
🔌 LS & LT Engine Wiring Harnesses​
  • Purpose-built harnesses designed for seamless engine swaps of LS and LT powerplants into classic cars and trucks.
  • Coverage spans multiple engine generations:
    • Gen II (LT) – e.g., LT1/LT4
    • Gen III (LS) – 24x crank, early LS variants (LS1/LS2, etc.)
    • Gen IV (LS) – 58x crank sensors (LS3, LS7, etc.)
    • Gen V (LT1/L83/L86) – newer LT engines
  • Includes:
    • Main engine harnesses
    • ECM/PCM wiring kits
    • Extensions (Oâ‚‚, MAF, sensor adapters)
    • Dash connectors (tach, speedo, TCC, MIL, DLC diagnostic port)
đź”§ ECM & Controller Packages​
  • Plug-and-play ECM kits pre‑tuned for classic swap applications:
    • Eliminates need for extensive aftermarket tuning
    • Configured for older vehicle electrical systems by disabling modern diagnostics
đź›  Accessories & Adapters​
  • Wide accessory catalog supporting swap installations:
    • Oâ‚‚ sensor and MAF extensions, pigtails, adaptors
    • Coil relocation and drive-by-wire pedal kits
    • Brackets, mounts, and sensor adapters
âś… Key Benefits​
  • “Plug‑&‑Play” simplicity – minimizes custom wiring hassles
  • Exact fitment – from Gen II to Gen V, aiding compatibility
  • Quality connectors – high-temp TXL wire, OEM-grade Delphi or GM connectors
  • Modular design – enables piecing together exactly what you need (e.g. just harness + Oâ‚‚ extensions)
đź§© Typical Setup Example​
  1. Choose the correct standalone engine harness for your engine’s crank sensor package (24x / 58x / LT).
  2. Add vendor ECM/controller package suited to engine-gen and classic vehicle wiring.
  3. Supplement with extensions or adapters for sensors like Oâ‚‚, MAF, coil packs.
  4. Include pedal and dash connectors if running drive-by-wire setups or retro-style gauge integration.
📝 Quick Reference Table​
Component TypeFunction/Contents
Standalone HarnessCore wiring for cranking/firing + key sensors
ECM/Controller KitPreprogrammed PCM + main harness integration
Sensor ExtensionsAdd-ons: Oâ‚‚, MAF, knock, coil relocation adapters
Pedal/Kickdown KitsDBW pedals, throttle/cable adapters
Bottom line: CPP’s LS & LT harness and accessory line is tailored for enthusiasts performing engine swaps into older vehicles. They offer generation-specific harness kits, plug-and-play ECMs, and necessary extensions to get your LS/LT engine running cleanly with minimal headaches.​
