If you’re restoring or building a cool daily driver and you're looking to dial in that perfect stance for your classic Chevy, Classic Performance Products has you covered. The CPP Front Coil Springs are available in stock height or 1", 2" or 3" drop springs engineered to lower the front end of your 1963-87 Chevy 1/2 Ton Truck, while maintaining the comfort and control you expect from a well-tuned suspension.
- Vehicle Fitment: 1963-87 Chevy 1/2 Ton Truck
- Drop Height: 1 to 3 inches lower than stock
- Material: High-strength spring steel
- Finish: Durable black powder coat for long-lasting protection
- Ride Quality: Tuned for improved stance without sacrificing comfort
Swapping out old, worn factory springs is more than a cosmetic upgrade. Over time, OEM springs can sag and impact both drivability and safety. CPP’s precision-wound coil springs not only lower your Impala’s front ride height for a sportier look—they also restore proper suspension geometry and road handling.
These springs are a direct replacement and work with your factory components or aftermarket upgrades like CPP's drop spindles and tubular control arms. Just install and enjoy the ride and look.
Maximize your ride quality by pairing these springs with CPP’s performance shocks. The combo helps absorb bumps, reduces bounce, and tightens up steering feel.
CPP Front Stock Coil Springs for 1963-1987 Chevy 1/2 Ton Truck, C10 Stock, Pair
CPP high-performance automotive parts for classic cars
Part # FCS6102-S
CPP Front 1" Drop Coil Springs 1963-87 Chevy 1/2 Ton Truck
Part # FCS6102-1
CPP Front 2" Drop Coil Springs 1963-87 Chevy 1/2 Ton Truck
Part # FCS6102-2
CPP Front 3" Drop Coil Springs 1963-87 Chevy 1/2 Ton Truck
Part # FCS6102-3
