CPP Modular Spindles – The Ultimate Upgrade for Your Classic Truck. No Cutting. No Guesswork. Just a Perfect Drop.
If you’ve ever tried lowering a classic truck the old-school way, cutting coils, swapping springs, or wrestling with geometry, you know it’s not always fun. CPP’s Modular Spindles change that game completely.
These are the spindles that make stance and performance come together without the headache.
Crafted from one-piece nodular iron with a pressed-in alloy steel axle pin, these spindles are built like a tank but designed to install clean, no frame mods, no welding, and no sketchy backyard fixes. Just bolt ‘em on, torque ‘em down, and enjoy a killer stance that looks right and drives even better.
Every classic truck deserves the right stance, and CPP delivers it with a true drop that doesn’t mess with your wheel placement. No added track width, no offset headaches. Your wheels stay centered, your geometry stays happy, and your ride instantly gets that tough, planted look we all crave.
Whether you’re rocking a C10, F100, or vintage Chevy pickup, this is the drop spindle setup designed to get it low and keep it right.
Big Wheels? No Problem. Classic trucks look best when they fill the wheel wells with something meaty.
CPP Modular Spindles were made for modern wheel and tire combos, and they’re built to handle larger bearings that can take the abuse.
That means smoother cruising, more durability, and the confidence to throw your truck into corners without worrying about old-school weak points.
Brake Compatibility You Can Count On. Here’s where CPP really nailed it, these modular spindles work with a wide range of brake kits and rotor sizes from CPP. Whether you’re bolting up a CPP Big Brake Kit, a Pro-Series 6-Piston setup, or a standard disc upgrade, the fitment’s dialed in.
You don’t have to play the guessing game with brackets, spacing, or alignment. Just pick your brakes, bolt them on, and hit the road.
Why Gearheads Love ‘Em
✅ Bolt-On Install: No frame mods, no welding.
✅ Drop: Aggressive stance without geometry headaches.
✅ Larger Bearings: Stronger and smoother for modern driving.
✅ Built CPP Tough: One-piece nodular iron for serious strength.
Whether you’re building a weekend cruiser, autocross bruiser, or shop-floor showstopper, CPP Modular Spindles give your truck the stance and strength it deserves.
Strong. Smart. Simple. CPP Modular.
So if you’re ready to drop your classic the right way, skip the shortcuts and bolt on the best.
Shop CPP Modular Spindles here:
Because when it comes to your truck’s stance and safety, don’t compromise, customize.
