PTK by CPP: The Ultimate Pro-Touring Foundation for Your Classic Ride
When it comes to transforming a classic car into a corner-carving, road-gripping, modern-handling machine, few upgrades make as dramatic an impact as a true Pro-Touring suspension package. Classic Performance Products (CPP) created the PTK Series, Pro-Touring Kits to give builders, restorers, and weekend cruisers a complete, bolt-on path to modern performance without sacrificing the soul of their vintage ride. Whether you’re dialing in a ’60s muscle car, a Tri-Five Chevy, or a street-driven track toy, the CPP PTK lineup is engineered to deliver the stance, control, and confidence today’s drivers demand.
What Makes PTK the Go-To System for Pro-Touring Builds?
The PTK line isn’t just a pile of parts — it’s a curated, stage-based system designed to grow with your build. CPP structured the lineup so customers can start simple, upgrade gradually, or jump straight into a full modernized suspension and braking overhaul.
Stage I – Better Geometry, Better Feel
PTK Stage I kits introduce the core foundation of modern handling:
  • Tubular upper & lower control arms
  • Upgraded coil springs
  • Front & rear sway bars
  • Fresh bushings and improved alignment capability
  • This stage alone instantly tightens steering feel, reduces body roll, and preps your chassis for future performance upgrades.
Stage II – Level Up Your Shock and Spring Game
Stepping into Stage II moves your build closer to a true pro-touring setup by adding:
  • CPP dual-adjustable shocks
  • Lowered performance springs
  • Fine-tuning flexibility to dial in ride height and responsiveness
This is where your classic starts feeling planted, composed, and sharp on turn-in.
Stage III – Coil-Over Control
Stage III adds:
  • Full coil-over conversion
  • Ride-height adjustability
  • Improved spring rates
  • Better rebound & compression control
Stage IV – Big Brakes, Big Confidence
If you’re adding horsepower, you need stopping power to match. PTK Stage IV includes:
  • 11" performance disc brake upgrades
  • Optional 13" / 12" Big Brake kits
  • Vented, drilled, or slotted rotor options
  • High-performance calipers
Why Builders Choose CPP PTK Kits
✔ Made in the USA
CPP engineers and manufactures the PTK line in-house for precision fitment and long-term durability.
✔ Complete, Bolt-On Packages
No guessing. No parts-hunting. No mismatched components.
Every PTK kit includes everything needed for a clean, predictable upgrade.
✔ Designed for Real Road Use
PTK kits deliver the blend of comfort, performance, and streetability that pro-touring fans expect — not a harsh race-only ride.
✔ Stance That Sets Your Build Apart
Lowered geometry, modern shock valving, and coil-over adjustability make it easy to get the look and performance you want.
The Perfect Upgrade for Classic Chevys, Novas, Camaros, Trucks & More
Whether you're assembling your dream restomod, restoring a family-owned classic, or prepping your car for autocross and road-course weekends, CPP PTK kits provide the flexibility and performance to bring your build to the next level. Pro-touring is all about blending classic style with modern capability, and PTK by CPP is the most complete path to get there.
Ready to Upgrade Your Suspension? Explore the full PTK lineup here:
