Corvette Style Front Disc Brake Kit w/ C7 Hubs W/ Stock Height Spindles
Chevrolet C10 Truck Parts
7081SWBK-SC7R  Corvette Style Front Disc Brake Kit w/ C7 Hubs W/ Stock Height Spindles, 1970-81 Camaro, 75-79 Nova, Red Calipers
The CPP CS series brake kits incorporate a newly designed direct fit spindle that is compatible with factory steering arms, providing a straightforward enhancement to your braking system. This spindle features a C7 bearing hub assembly, which addresses the flex associated with the original spindle pin, a problem that can lead to caliper piston pushback, especially when using aftermarket multi-piston radial mount calipers. Included in each kit are 13” C5 drilled and slotted rotors, along with C5 twin piston calipers and stainless steel hoses to improve performance.
This kit is specifically designed for vehicles with 17-inch wheels or larger, making it an excellent choice for those looking to optimize performance with 18-20” wheels.These brake kits come with a 5 on 4.75 bolt pattern and utilize 7/16 x 20 studs, while the C7 hubs are fitted with 1/2 x 20 holes, providing the option to upgrade to larger studs if necessary. This brake kit is suitable for 1970-81 F Body and 1975-79 X Body applications.
