Big Bore Calipers - Features
🔧 Core Features​
  • Direct GM Metric Caliper Replacement
    Designed as a drop-in upgrade for vehicles using original GM S‑10/metric front calipers—no modifications required.
  • 20 % Larger Piston Bore
    Boasting a 2.75″ (70 mm) bore—about 20 % larger than standard GM metric calipers—for significantly improved stopping force.
  • Reversible Caliper
    Can be installed on either side of the vehicle. Both the bleeder screw and brake hose use a 10mm x 1.5 thread, just be sure the bleeder is positioned at the top when mounted.
🏗️ Construction & Finish​
  • Durable Cast-Iron Body
    Rugged cast-iron build ensures longevity; available in natural or powder-coated red & black finishes for extra protection.
  • Smooth Casting Ideal for Finishing
    Clean cast surface is ready for chrome or powder coating—great for custom builds.
🛠️ Hardware & Specs​
  • Loaded Calipers: Pads & Pins Included
    Each caliper comes complete with D154 pads, clips, slide pins, banjo bolt (10 mm × 1.5), washers, and bleeder screws.
  • Banjo Bolt Size
    Standard 10 mm × 1.5 banjo bolt compatible with GM metric setups.
  • Sold in Pairs
    Left/right pairs priced around $139 (black powder-coated) or $99 each each for powder coated red (single).
🛡️ Performance & Benefits​
  • Enhanced Braking
    Larger pistons deliver more pad force with better modulation and reduced fade.
  • Simpler Maintenance
    Dual bleeders make bleeding easier and eliminate the risk of side mix-up.
  • Long-Term Durability
    Users report strong, reliable performance well after long-term use.
⚙️ Compatibility & Fitment​
  • Vehicle Fitment Examples:
    • 1978–1988 Chevy Midsize & 1983–2002 Chevy S‑10 trucks (GM Metric).
    • Broad application across GM metric IFS systems (Mustang II spindles, classic Chevy trucks, etc.).
  • Complete Kit Availability:
    Also available in Big Brake Kit versions with larger calipers (52 mm twin pistons), rotors, hubs, hardware, and hoses for full upgrades.
🚘 Summary Table​
FeatureDetails
Piston Diameter2.75″ (~70 mm)
Bore Increase20 % over stock
Bleeder ScrewsDual – both sides bleeder
MaterialCast iron
FinishesNatural / powder coat (black/red)
Hardware IncludedPads (D154), clips, pins, banjo bolt, washers, bleeders
Banjo Bolt Size10 mm × 1.5
Price (Pair)Details
WarrantyStandard CPP limited warranty
🧩 Why Choose Big Bore?​
  1. Noticeably stronger braking with improved modulation.
  2. Simplified installation & bleeding, especially helpful for DIYers.
  3. Finished aesthetics tailored for custom builds.
  4. Turnkey solution with all hardware included—no need for extra parts.
